Swapping warn 360 magnum for 318 w/ low miles
Old Mar 15, 2016 | 08:19 PM
RamSport9859's Avatar
RamSport9859
Okay cool. Will I need to put the flex plate off the 5.9 to the 5.2? And by dropping the engine in and wiring you mean just use the wiring that's already in the truck for the 5.9? Or 5.2 wiring?
Old Mar 15, 2016 | 08:33 PM
No, use the 5.2 flexplate. Use the wiring that is already in the truck. There *might* be some differences in connectors, if there is, just swap in the correct year sensors.
Old Mar 15, 2016 | 08:39 PM
RamSport9859
Will the flex plate bolt up to the transmission, the trans is a 46re out of a ram with a 5.9, and what do you mean by correct sensors exactly? Lol sorry for so many questions this is the biggest swap I've done before and still have a lot to learn.
Old Mar 15, 2016 | 08:52 PM
The engine will bolt to the trans, but, I would check the flexplate on the torque converter before dropping the motor in. It *might* be different, but, I don't think so.
The 98 sensors will be the 'correct' sensors. They are all pretty much the same between the v-8's anyway.
Old Mar 15, 2016 | 09:01 PM
RamSport9859
Oh okay, so just plug everything together, I may have some extra wires that aren't plugged in. Are there really any difference between a 5.9 from 97-98? Or are they the exact same
Old Mar 16, 2016 | 07:42 PM
RamSport9859
Ok so the guy who had the engine sold it already, so I just plan on rebuilding the 5.9 since I already removed it from the truck. I looked at summit racing and they have engine rebuild kits, but they have them for many years except 98-01, are all the 5.9 magnums the same from 94-01?
http://m.summitracing.com/parts/fem-205-6378m000 Will this rebuild kit work with my 98 5.9???
Old Mar 16, 2016 | 07:55 PM
RamSport9859
Also, would I need to have the block honed out? Or have it bored? It's got 212xxx on the clock, burns some oil. But runs good for having that many miles on it. Motors out sitting on a big tire, I can tear down the block within half hour. Just don't know exactly what I should do with it.
Old Mar 16, 2016 | 11:40 PM
getdown78's Avatar
getdown78
Northern engine supply has rebuild kits cheap !
Old Mar 17, 2016 | 12:39 AM
UnregisteredUser's Avatar
UnregisteredUser
More than likely one or the other will be required. The hot ticket is to let the machine shop decide, unless you want it overbored for some other reason.
Old Mar 17, 2016 | 05:22 PM
And don't even bother with the stock heads, just toss 'em. Buy a new set from Odessa, or Clearwater... the NEW castings, with the thicker deck.
