Auto Tranny Shift Kit
Old Nov 8, 2005 | 04:12 PM
94Champ's Avatar
94Champ
Default Auto Tranny Shift Kit
For all of you that have been contemplating putting in a shift kit , I just put in a Transgo kit with an APS TV assembly, No Buzz valve and Aluminum Accumulator with Blocker Rod from APS transmissions in my truck. Much better,firmer shifts and after checking 2 tanks consistantly gained just under 1/2 mpg around town. Took about 4.5 hours to install.
Old Nov 8, 2005 | 08:52 PM
steve05ram360's Avatar
steve05ram360
Default RE: Auto Tranny Shift Kit
nice, how much was the other upgraded parts? also did you go with a deeper pan with the drian plug/temp sensor bung?
Old Nov 9, 2005 | 12:16 AM
94Champ's Avatar
94Champ
The Transgo kit was $94,the other items + pan gasket,filter and trans-lube was $179 + $15 to ship it. I stayed with the original pan as I have a stand alone tranny cooler and pillar temp guage, the hottest it's ever got is 170 degrees while wheeling.I had installed a drain plug about a year ago when I did a filter change.The whole thing from APS was a kit, they have 4 stages and I went with stage 3. Quite happy with the results.
