Mopar Performance Intake Questions
Old Mar 22, 2016 | 05:52 PM
wjamesbass's Avatar
wjamesbass
Good catch! I knew there was something screwy about the price on it!
Bookmark deleted!
Old Mar 22, 2016 | 07:01 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by dapepper9
but wholly useless on anything where performance is the desire.
But if performance is the desire you use the Ram to tow it, not to be it.
Old Mar 23, 2016 | 09:47 AM
dapepper9's Avatar
dapepper9
Well "performance" however mild is still fun. Hence why I'm Vortech'n mine lol
Old Mar 28, 2016 | 07:09 PM
LIZZRD's Avatar
LIZZRD
Don't want to loose your low RPM grunt ? , then the M 1 is not what you need .
The M1 is a single plane and the dual plane ( F 1 ? ,will serve best from idle to,
whatever, 4500 -5000 rpm. I am considering an upgrade so i have been looking/reading alot , i may have gotten Air Gap manifolds, Edelbrocks , etc. mixed up.
Old Mar 28, 2016 | 08:54 PM
Spillage's Avatar
Spillage
Like the M1, the FIAirgap also looses some low end due to shorter runners.
This low end loss is typically offset by gains from other mods, and the combination of mods gives good mid range performance.
Sadly, most aftermarket bolt-on stuff seems to be aimed at mid to top end for racing, and its use for daily drivers never gets the desired results.
Old Mar 29, 2016 | 12:48 PM
Moparite's Avatar
Moparite
Checkout the link below, There are a few more options but they are for the carbed magnum motors that either have the ports for the injectors or need to be machined out. Adapter for the tb is also needed. I'm liking the Indy modman with this on top of it!
http://www.allpar.com/mopar/performance/manifolds.html
Old Mar 29, 2016 | 06:14 PM
LIZZRD's Avatar
LIZZRD
Spillage , do you have a single 3" exhaust ? How do you like it ?
My most important problem now is an exhaust leak at the manifold , so thinking of getting a set of headers and then have a local guy put together a single 3" Y and SS piping , welded with two O2 bungs.
Other mods will have to follow...
Old Mar 29, 2016 | 06:29 PM
LIZZRD's Avatar
LIZZRD
Thanks for the link ...
Old Mar 29, 2016 | 06:38 PM
Spillage's Avatar
Spillage
Yes, 3" all the way.
Pacesetter LT headers (72C2213) and off-road 'Y'-pipe (82-1183)
Magnaflow 3" muffler (#12279) and tail-pipe (#15035)
Magnaflow 4" tip (#35107)
I'm very happy with it.
Old Mar 30, 2016 | 05:39 AM
AtomicDog's Avatar
AtomicDog
I'm also running 3" single exhaust and love it. I'm running JBA coated shorty headers, a Dynomax UltraFlo Welded Muffler #17233 and Magnaflow Converter - 99047HM (dual 2" inlets, 3" outlet, front O2 sensor port). Had to have a O2 bung welded into the pipe behind the cat. The system works great and sounds nice and mellow.
As for the M1 intake, you can find them used from time to time. I purchased mine via my local craigslist. They also pop up on eBay, too.
