93 vs 99 5.9 magnum
Old Mar 29, 2016 | 11:48 PM
timberbeast5.9's Avatar
timberbeast5.9
Default 93 vs 99 5.9 magnum
just wonderin if someone could tell me if a 99 5.9 magnum out of a durango would work in my 93 pickup with the 5.9 magnum?
Old Mar 30, 2016 | 12:09 AM
dbbd1's Avatar
dbbd1
Others, smarter than myself, will chime in but...
I think the 93 is obd1 vs the 99 being obd2. I know you will need the PCM from the 99 and most of the electronics and sensors.
Old Mar 30, 2016 | 12:20 AM
timberbeast5.9
that makes sense. i wonder if i could just swap intake manifolds and use the older one on newer engine. just curious cause my heads are cracked and have water in oil now
Old Mar 30, 2016 | 12:34 AM
frankie_b_jr's Avatar
frankie_b_jr
Head might be cheaper if the rest is good. Odessa Clearwater cylinder heads on ebay.
Otherwise, yes you can swap them, but you'll need your manifolds and sensors. All else should be plug and play.
Last edited by frankie_b_jr; Mar 30, 2016 at 12:38 AM. Reason: Re-read original post.
Old Mar 30, 2016 | 12:35 PM
timberbeast5.9
ok thanks for the info. i found the 99 engine pretty cheap in my area so it would be cheaper for me to get whole engine
Old Mar 30, 2016 | 01:08 PM
dbbd1's Avatar
dbbd1
Sounds like the ticket. Swap what you need, although most will tell you to oh with aftermarket heads. Depends upon how much $ you have.
