1998 Dodge Ram 2500 Catalytic Converter Removal
Old May 11, 2016 | 08:15 PM
CajunCountry's Avatar
CajunCountry
Default 1998 Dodge Ram 2500 Catalytic Converter Removal
I'm currently trying to remove my cat converter from my '98 Ram 2500, but noticed that there is 2 pipes leading into it, while one leads out. How can I lead the pipes to make everything flush. Also, how do I go about my 02 sensors? Thank you for any help.
Old May 12, 2016 | 07:38 AM
Moparite's Avatar
Moparite
I'm assuming you are replacing it? Remove the bolts on the exhaust manifold. This may be tricky because mine where so rusted no socket would grab it. I had to cut the bolt with a die grinder to get them off. Make a cut on the pipe where it connects to the exhaust pipe and you can take the whole thing off. Get new NTK 02's
Old May 12, 2016 | 03:03 PM
CajunCountry
I actually don't have the money for a new cat converter at the moment. I was planning on cutting the single pipe leading out behind the unit, breaking the honeycomb, letting it blow out, and reclamp the pipe together.
Old May 12, 2016 | 03:08 PM
That works too..... IF you don't have emissions testing/inspections where you are.
Old May 12, 2016 | 03:57 PM
schmidtp's Avatar
schmidtp
Do you or a friend have access to a welder?
Old May 12, 2016 | 05:00 PM
Adobedude's Avatar
Adobedude
Exactly what I did on my 98 Ram 2500, no emissions where I live, for now.
