problems with vents
Old May 25, 2016 | 03:23 PM
dylen548's Avatar
dylen548
Default problems with vents
i have another problem with my truck. well when i turn the heat or ac on it only blows through the driver side windshield and side vent and barely blows through the passenger side and when i switch it to the front dash vents it dont come out but continues to blow through the driver side windshield vents
Old May 25, 2016 | 03:24 PM
Search "wild vents". That may be a contributing cause.
Old May 25, 2016 | 03:38 PM
dylen548's Avatar
dylen548
i dont think thats the issue at all this issue occurs either the truck is moving or not
Old May 25, 2016 | 04:13 PM
Are the vents not switching at all? That's a vacuum problem. need to check the lines on the passenger side of the intake, and make sure something ain't broke.
Old May 25, 2016 | 08:09 PM
dylen548's Avatar
dylen548
yeah vents dont switch and the driver side defrosters are the only ones that work
Old May 25, 2016 | 08:10 PM
dylen548's Avatar
dylen548
and i did check those lines on passenger side they seem fine
Old May 25, 2016 | 08:14 PM
Then you need to check and see if you are getting vacuum to the control head.....
Old May 25, 2016 | 09:06 PM
dylen548's Avatar
dylen548
and were is the control head?
Old May 25, 2016 | 09:07 PM
Yes. That. My point in mentioning the wild vents thing was its 9 times out of 10 a vacuum related issue.
Old May 26, 2016 | 12:01 AM
That's the part in the dash with the ***** on it. All the vents are controlled by vacuum, temp is controlled by a little motor under the heater box. Need to verify you are getting vacuum TO the control head, else, nothing is gonna work.
