98 1500 Transmission seal question
Old Jun 6, 2016 | 11:42 AM
ljinnc's Avatar
ljinnc
Default 98 1500 Transmission seal question
Hi, I have a 98 Ram 1500 with 46re and 5.2 v8, I have a leak from the bellhousing of transmission fluid, so I guess I need to change the front seal. How hard is this besides dropping the tranny?
Old Jun 6, 2016 | 12:09 PM
Drop the trans, pull the converter, change the seal. 4-6 hours, depending 2 or 4wd.
Of course, JUST changing the seal may only be a temporary fix...... While you are in there, trying to figure out WHY it started leaking would be a really good idea.
Old Sep 3, 2016 | 09:14 AM
ObsoleteJim's Avatar
ObsoleteJim
Have same problem. What would be the most likely reasons for leak other than bad seal?
Old Sep 3, 2016 | 09:49 AM
Bad pump, or converter.
Old Sep 4, 2016 | 09:58 AM
Brian in Tucson's Avatar
Brian in Tucson
There's a grommet/seal where the dipstick goes into the trannie--mine was bad and leaked oil there. Fairly easy to check & replace. Very inexpensive part found in the Help section of Autozone, O'reilly's, etc.
Because ATF+4 is so thin, a leak anywhere in the area can look like a leak from the bellhousing.
