Squeaky brakes...
Old Jul 1, 2016 | 05:02 PM
Alex Andrew Orndorff's Avatar
Default Squeaky brakes...
Does anyone here seem to have an issue with their drum brakes because they don't stop screeching? I've replaced the shoes and drums and all the hardware, made sure they were adjusted properly. Think maybe cheap shoes? I did get them aftermarket because OE from dodge was over $200! Ridiculous. Whenever I take the drum off and clean the brake dust out, BAM! No screeching at all for about a week and a half. But I'm getting tired of cleaning out the drum to take away the screeching. Also have 35s so it takes a bit more to stop the truck. But others I've seemed to ask about the say their brakes don't squeak. Just wondering if anyone has encountered the same thing.
Old Jul 1, 2016 | 07:50 PM
BigGreenRam's Avatar
BigGreenRam
Well your 35s are a very big tire to slow down will oe brakes bite the bullet spend the money and get better Heavy-duty brakes on both axles. I have 33s and need to up grade mine think bout it may save your life or somebody's life have a good day and welcome to DF
Old Jul 1, 2016 | 11:31 PM
I mean my brakes work fine. It's just they squeak.
Old Jul 2, 2016 | 09:50 AM
Install better quality shoes?
Old Jul 2, 2016 | 02:59 PM
dbbd1's Avatar
dbbd1
Broke them in?
Old Jul 2, 2016 | 07:06 PM
I'm installing new ones tomorrow. I'll see how it goes. It'll take a couple weeks to know if that was the problem or not.
Old Jul 3, 2016 | 09:06 AM
racefan41's Avatar
racefan41
when you clean the drums are you using emery cloth or light sandpaper to take the varnish off the surface? using brake lube at your contact points too?
Old Jul 3, 2016 | 11:34 AM
Yeah I Lube up all contact points. And when I clean out the drum after a couple weeks driving all I do is just take it off and spray brake clean everywhere because there is so much brake dust already. I don't ever try to take sandpaper to the surface though. That usually will take away the squeaking for a couple weeks. Then it comes back and it sounds horrible. So when I get fed up with it I take the drum back off and do it all over again.
Old Jul 3, 2016 | 12:33 PM
racefan41's Avatar
racefan41
it might help, I don't know. I do it anytime I clean em up. same with the shoes.
but yeah, better shoes sound like the best bet
