160 amp alternator installed
Old Jul 20, 2016 | 06:24 AM
renardk764's Avatar
renardk764
Default 160 amp alternator installed
So, after getting the 390 installed, I noticed a significant voltage drop during idle. I attributed it to the combination of e-fans, headlight wiring upgrade, and additional gauges. My build sheet indicated the truck came with a 117 amp alternator. So I went on a search for a higher amp alternator. The typical swap, pocket book friendly, is to install the 136 factory alternator. I ran a quick down and dirty calculation and determined that 160 would been the minimum I should install. Looking around, 180 amps running around 300 bucks was what I looking at. Then I ran across a thread on one of the Dakota forums indicating the 160 amp from a 2001 Durango is an exact fit. Lo and behold it is. No modification needed and slides right in. This was a much easier expense to swallow at about half the price and readily available at local parts houses if it fails. Just sharing in case anyone else is in the same boat.
Last edited by renardk764; Jul 20, 2016 at 11:46 AM. Reason: spelling and some minor corrections
Old Jul 20, 2016 | 09:31 AM
dbbd1's Avatar
dbbd1
Great info, thanks.
Old Jul 20, 2016 | 01:05 PM
renardk764's Avatar
renardk764
Welcome
Old Jul 21, 2016 | 12:09 PM
Moparite's Avatar
Moparite
When you up the amp output of the alternator you should change the fuse to match the alternator in the distribution center.
Old Jul 22, 2016 | 08:02 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Good tip on the alternator!
Old Jan 12, 2017 | 10:21 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
renard....still humming along?
Old Jan 12, 2017 | 01:27 PM
ram-tuff's Avatar
ram-tuff
What size fuse would that need to get upgraded to?
Old Jan 12, 2017 | 02:53 PM
dbbd1's Avatar
dbbd1
IIRC, the stock fuse is 100a for a 120a alternator. I would go up to about 150a for the 160a alternator.
