1995 Gauge cluster swap info
Old Jul 21, 2016 | 11:25 PM
jodaddy's Avatar
jodaddy
Default 1995 Gauge cluster swap info
I have a 95 ram 1500 5.2 5speed with the base cluster and I want a tach so I picked up a set of gauges from a 94w/ tach. plugged it in and everything works perfect but the tach. I'm thinking there must be a wire somewhere that needs connected for it to work or maybe even a fuse installed. I have the base model with manual everything. I can't seem to find a decent wiring diagram in my manual so any ideas/ help would be great. thanks, Joe
Old Jul 22, 2016 | 10:45 AM
I do believe it is indeed just one wire...... Doing this swap is real hit and miss though. For some folks, it worked fine, for others, it didn't......
Grab the 95 service manual from this thread. Should have better diagrams for ya.
Old Jul 23, 2016 | 05:19 PM
jodaddy's Avatar
jodaddy
wire is missing from my harness from firewall to pcm. Chrysler must have been trying to save a few pennies. Going to try to run a new wire and see what happens. thanks for your help. Joe
Old Jul 23, 2016 | 08:08 PM
I would bet that all you have to do is run the wire. The PCM is probably putting out the signal, regardless if the wire is there or not.
Old Jul 28, 2016 | 12:27 AM
jodaddy's Avatar
jodaddy
success. after staring at the diagrams for 3 days and realizing I was trying to put a new wire into the wrong pin out on the computer I finally got it. It was missing a section of wire from the out side of the firewall to the inside of the firewall. A couple feet of wire and two connectors and the tach sprung too life. Now I am going to try for the low fuel light. thanks for all your help. I really appreciate it. Joe
Old Jul 28, 2016 | 09:46 AM
dbbd1's Avatar
dbbd1
Great, knew you would nail it!
Old Aug 27, 2016 | 11:13 AM
jodaddy's Avatar
jodaddy
So the low fuel light works with no other mods/wiring.
