Tie Rods
Old Nov 11, 2005 | 01:59 AM
CopperDesigno's Avatar
CopperDesigno
Default Tie Rods
I am in the process of replacing both my outer tir rods and I hit a snag, well the second snag. The first being my puller sipped and ruined the nut, so I had to cut the nut off with a hacksaw.
The second snag being I can't twist the left outer out of the adjuster sleeve, even though the adjuster sleeve bolts are both loose and jiggle. Did I miss something? As I type this two thought popped into my head, I could heat the sleeve and see if that breaks the crud free. Or I could take a wedge (old screwdriver) and wedge it in the slit on the sleeve to try and pop it it free?? Any thoughts?
I left the sleeve with some penetrating oil to soak over night.
Thanks
Old Nov 11, 2005 | 03:16 AM
livinginh's Avatar
livinginh
Default RE: Tie Rods
well the penetrating oil will help. But if you have ever watched someone at an alignment shop. They have a special tool that looks like a funny wrench with a hook on the curved part, it slips around the sleeve and hooks into the slot and you turn it just like any other wrench. You can try a screw driver or small pry bar, but be careful not to spread the sleeve open to far that it wont align right again. I always use a pipe wrench, seems to work well.
Old Nov 11, 2005 | 10:36 AM
CopperDesigno
Thanks, I thought of something else, the threads may be left hand on one side of the sleeve and right hand on the other. I think I read it somewhere or saw it on a part diagram?
Old Nov 11, 2005 | 07:06 PM
4DrMopar's Avatar
4DrMopar
yep! threads both directions...
Old Nov 11, 2005 | 09:02 PM
CopperDesigno
I figured the reverse thread item out. The adjuster sleeve I was fighting with never gave up so I ended up buying a new sleeve and new inner tie rod :-(
Everything went back together with no hitches though, that's always good.
I wanted to wirte a DIY article for doing all this, but my batteries were dead in the camera, and now that everything is done, my camera would have been a greasy mess by now.
