Heater control problem 00 Ram 1500
Old Nov 11, 2005 | 11:14 PM
J3cubfan's Avatar
J3cubfan
Default Heater control problem 00 Ram 1500
Hey Guys and Gals:
I have a problem with my heater. I get one temperature and that is hot, which isn't bad since we are getting ready to go into winter. Here's what happening. The heater controls that operate the temperature do not work. When they did, I would here a low humming noise when moving the controls from. So even if the controls are on cold, the temperature is hot.
I am thinking that it might be the thermostat, but not sure. Any ideas...
John
Old Nov 11, 2005 | 11:49 PM
steve05ram360's Avatar
steve05ram360
Default RE: Heater control problem 00 Ram 1500
it's not your t-stat. most likely your climate control module has a problem. I havent had that problem so that's about all I can say at this point...
Old Nov 12, 2005 | 01:16 AM
J3cubfan's Avatar
J3cubfan
Any ideas as to what it would take to replace it?
Old Nov 12, 2005 | 02:15 AM
draftingmonkey's Avatar
draftingmonkey
Theres a couple of things it could be. If the cowl air intake is not blocked and the blower is working properly. It could be as steve says a faulty heater/ac module, or a blend-air door servo motor could be out. It can be quite involved to fix, anything from vacuum/electrical tests to pulling the instrucment panel and ac/heater ducts to get to servo motor. You really need some sort of manual to be able to check all the possibilities. Good luck.
Old Nov 30, 2005 | 10:46 AM
J3cubfan's Avatar
J3cubfan
Hey Guys:
Found out what it was. There is a plastic door that redirects heat from the heater core when the temperature is turned to full cold and moves when the temperature is turned to warm then hot. This is something that the servo motors. Anyway, the door itself is plastic and when you put the hot and cold extremes over the course of 5 years, yep you guess it. The door broke off.
So with that, the dashboard gets to come back out along with the box that has the heater core and the evaporator. Sheesh, I wish that Dodge would get the heater and A/C controls correct on these things. Come on how hard can this be? [sm=confused06.gif]
I spoke with a mechanic and he said that we see about 3 Chrysler vehicle in here a month with the same problems. I asked him if the problem had been addressed with the Magnums, and Chargers. In his opinion, it really hadn't...
Old Nov 30, 2005 | 10:59 AM
ljpierce_ely's Avatar
ljpierce_ely
If you have to go through all that to fix the problem, there is one other item that may, and I stress MAY, be a good thing to replace. The Heater Core. I've been told that to replace those, the dash has to come out. Fortunately, I haven't had to do that yet.
The only reason I suggest this is that I hate to repeat the steps to get at something that goes bad, when I was just in there a few days/weeks/months before. Especially as difficult as pulling the dash out.
Just my 2 cents worth.
