99 Ram, possible fuel problems, I think
Old Aug 30, 2016 | 04:12 PM
dtrumbower's Avatar
dtrumbower
Default 99 Ram, possible fuel problems, I think
I have a 99 2wd Ram 1500. The other day while drive, it felt like I lost power. Put in neutral and then drive and vehicle kept going.
Made a few stops and all went well. 2nd to last stop the engine died. Tried to get it going and it would start but when gave it more throttle it would die.
After 15 minutes it started and drove to last errand, where it died.
I could get it to start with starting fluid but not stay running.
I get home and check Fuel Relay and ASD relay. They all checked out.
Didn't put a fuel pressure gauge on but when pressing the schrader value in the fuel rail, most of the time nothing came out. One time I had fuel come out.
Sure is looking like a fuel pump. Heck I have over 230,000 miles on the vehicle and pump.
Remove tank. Check the wire harness and get power when key is turned on. Crank engine the power meter surges, like it's suppose to.
Take fuel pump out and do an ohm test on the fuel gauge sender pins and they check out. Next I take a 9v battery and attach it to the ground and relay output pin. The pump runs.
So do I have a fuel pump problem or something else, Hate to purchase new fuel pump if the problem is something else.
Any ideas?
Thanks
Old Aug 30, 2016 | 04:37 PM
Just because the pump will run, doesn't mean it is putting out adequate pressure. Really need to put a gauge on it, and see what it has to say, but, my guess is, it's pump time.
Old Aug 30, 2016 | 05:20 PM
dtrumbower's Avatar
dtrumbower
I tested in bucket of water and would expect it to pump more. Sometimes it worked, sometimes it didn't.
New one will be ordered.
Old Aug 30, 2016 | 05:45 PM
Delphi, or Denso please. Skip the air-tek, or other 'off' brands. Unless of course, you LIKE doing this......
