Killing the battery
Old Sep 29, 2016 | 04:05 PM
mrbubblemaker's Avatar
mrbubblemaker
Pin 30 will be hot at all times.
Thanks. Something is staying hot and fryed the new battery and new fuel pump. The alt will freeze up while setting but loosens up when the truck starts. Could alt be causing it?
Old Sep 29, 2016 | 04:24 PM
It's possible...... Does the fuel pump continue to run after you shut off the truck?
Old Sep 30, 2016 | 06:11 AM
ramsportrocks's Avatar
ramsportrocks
if the internal regulator is shorted it will drain a battery completely overnight
and can KILL IT but I have never seen a shorted alternator burn up a fuel pump
ALSO common sense says if the alt " freezes up while sitting " it needs replacing before moving forward with any other issues
Old Sep 30, 2016 | 12:18 PM
mrbubblemaker
You're right about that.. I'm gonna have the alt checked and I've already ordered an external fuel pump for it. I don't particularly care for the internal.
Old Sep 30, 2016 | 07:09 PM
Gotta drop the tank anyway, as you don't want to be trying to pull fuel thru the dead one.
If you replace the in-tank pump with a good replacement, denso, or delphi pump, it'll last quite a while.
Old Oct 1, 2016 | 06:22 AM
ramsportrocks
Originally Posted by heyyou
gotta drop the tank anyway, as you don't want to be trying to pull fuel thru the dead one.
this!!!
Old Oct 1, 2016 | 10:04 AM
Moparite's Avatar
Moparite
I'm thinking that circuit stayed on and zapped my new battery and burnt out my new fuel pump
It will drain the battery but not burn out a pump. The fuel pump is submersed in gasoline to keep it running cool. It should last 100K or more depending on the pump. You should make sure it's bad before you replace it with an external. Since the alternator is "freezing up" and there may be a bad diode in it(this can drain the the battery) think it's time for a new one!
