new timing chain slack?
Old Oct 13, 2016 | 03:08 AM
emattern06's Avatar
emattern06
Default new timing chain slack?
Hello,
So I just installed a new double roller timing set while I was doing my plenum and I noticed then it seems kind of loose for a new set... Is the extra slack taken up by oil pressure when the motor is running or..? I am almost finished with work and want to make sure this isn't a huge problem before it's too late. Thank you
5.2L V8 Mag
2001 Dodge ram
108k
Old Oct 13, 2016 | 06:28 AM
stewie01's Avatar
stewie01
I installed the Cloyes Double Roller on mine long ago, there was a tiny bit of slack after installation, I'd like to think that's normal, can't see how it would go on if there wasn't a little bit of wiggle room.
Old Oct 13, 2016 | 08:50 AM
AtomicDog's Avatar
AtomicDog
A little slack is pretty common. Unfortunately, even double row timing chains will stretch a bit with use. I really like using the Mopar Performance small block timing chain tensioner to keep tension on the chain at all times, which keeps timing rock steady for years.
https://www.summitracing.com/parts/d...mXgaAooS8P8HAQ
Old Oct 13, 2016 | 10:18 AM
Ramman18's Avatar
Ramman18
Yep, almost same slack as the stock chain. Depends where the gears line up.
