Transmission Pan Gasket Bulging when torquing to proper specs
Old Oct 19, 2016 | 02:01 PM
chad.taylor.fsu's Avatar
chad.taylor.fsu
Default Transmission Pan Gasket Bulging when torquing to proper specs
I have a 96 Ram 2500 with a 47RE. I bought the WIX transmission filter and rubber gasket set from O'Reillys to replace a cork gasket that was leaking when the bolts were torqued down. I've looked online and in my Haynes and Chrysler Service Manual and they all say either 150 in pounds or 13 foot pounds of torque. I can't get more than hand tight before the rubber gasket starts to bulge out. Do I need to swap out for another gasket? The motor has 250,000 miles on it and the tranny was rebuilt at 200,000. Also, What brand of ATF +4 do you recommend? I've heard Castrol is great. I am thinking about just upgrading to a deeper pan with a drain plug. Any recommendations? Thanks everyone. I know I need to fill out my accessory information. I will get to it
Old Oct 19, 2016 | 02:20 PM
renardk764's Avatar
renardk764
From what I've read ATF+4 licensing requirements are so stringent that one brand isn't really any better than another. That being said, I've been sticking with Castrol. Bolts should be torqued to 13 ft lbs per the factory service manual. I do it in a sequence similar to installing valve cover gaskets. Kind of a crisscross pattern and 3 ft lbs, 6 ft lbs then 13. No bulging or leak issues
Old Oct 19, 2016 | 06:36 PM
Make sure the sealing surface, especially around the bolt holes, is flat...... some folks tend to over-torque the bolts, which deforms the sealing surface. Makes it hard to get it to seal properly.
Welcome to DF!
Old Oct 19, 2016 | 08:08 PM
AtomicDog's Avatar
AtomicDog
This is probably the nicest deep pan you can buy:
http://www.jegs.com/i/TCI/890/128015/10002/-1
