Elecrical issue?
Old Oct 29, 2016 | 11:47 PM
Originally Posted by 97ramrod1500
Alright so I got everything all straightened out now. I pulled the governor solenoid and sensor out of both transmissions to swap them. Turns out the 2001 trans had a different connector for the governor sensor. So I dropped the valve bodies and swapped the electrical harness from my 99 trans into the 2001. Also swapped all of my sensors into the new trans. That cleared up the temp light and overdrive issue.
Brake, abs and speedo were still a problem so I changed the sensor in the rear diff. Turns out that went bad at the same time as the trans went out. Changing the sensor fixed the issues. So far I've put about 50 miles on everything and it seems to be alright so far.
I'm still planning on having my original trans rebuilt. Should I stay away from the stage 2 transmission rebuild kits on eBay or are they decent? They appear to be the quality ones.
Look at this on eBay http://www.ebay.com/itm/272029129819
Awesome, glad things are workin' for ya.
That trans kit actually looks pretty good......
Old Oct 30, 2016 | 09:00 AM
97ramrod1500's Avatar
97ramrod1500
That's what I was thinking too. The only thing is it doesn't include the electronics but I will email them and see if they offer them. Of not, I can always purchase those seperate.
