No injector pulse?
Old Oct 30, 2016 | 05:32 PM
Then you need to find out why. A scanner that can read data would be good to have here.....
Are any of the codes resetting?
Old Oct 30, 2016 | 05:33 PM
GB93's Avatar
GB93
Well when I hook into the obd2 it says no codes but when I flick the key 3 times my truck says PO0320 but obd2 says no codes ?
Old Oct 30, 2016 | 05:38 PM
Might be a pending code.....
Indicates bad cam sensor.
Old Oct 30, 2016 | 05:39 PM
GB93's Avatar
GB93
I put a new one in it and put the old one back in it no change could they be bad ?
Old Nov 3, 2016 | 01:43 PM
GB93's Avatar
GB93
Got a noid light going to test injectors when I get home if I don't get a pulse where do I go from there?
Old Nov 3, 2016 | 04:21 PM
Cam sensor.
Old Nov 3, 2016 | 04:29 PM
GB93's Avatar
GB93
Could the new one that I put in be junk? I even put my old one back in and still the same I have power to the sensor
Old Nov 4, 2016 | 09:37 AM
Anything is possible, should still have some warranty......
According to theory, the PCM wants signal from both cam, and crank sensors, in order to know which injector to fire when. Since you are getting spark, that implies the crank sensor is doing its job.... that leaves the cam sensor.....
If changing the sensor doesn't help.... could be a bad PCM.
Old Nov 4, 2016 | 09:38 AM
GB93's Avatar
GB93
Ok ordered a new cam sensor we will see what happens
Old Nov 8, 2016 | 09:31 PM
GB93's Avatar
GB93
Put new cam sensor in tonight still just cranks going to send the rebuilt Ecm back and have them test it ? That's all I can come up with
