No injector pulse?
Changed cam and crank sensor put a rebuilt Ecm in my truck 2000 dodge v10 - I have spark spray starting fluid in the throttle body and it fires up and dies it also has a new fuel pump no injector pulse I get power to the injectors but no pulse ?
I can't read data with my scanner just codes my truck gives me the PO320 on the odometer which is the crank sensor I put a new one in it and it's getting spark and I have power to the injectors could the rebuilt Ecm have a problem?
Entirely possible.... Wouldn't be the first time someone got a bad PCM, with the exact same problem as the one they replaced.....
Trending Topics
So here's the deal drove the truck home 500 miles when I got it - drove it around a while and went out and parked it then no start that's after I put a new fuel pump in it changed cam and crank sensor got a used pcm off eBay with the same program as my truck the truck fired right up - drove it around and then it just died I lost all communication with the pcm the original one and the used one it would not read on the obd2 and odometer kept saying no bus so I ordered a rebuilt pcm put it in and the truck fired up 3 times and just dies after about 5 seconds now all it does is crank I have power to coils I'm getting spark power to injectors spray starting fluid in and it starts
