Power Steering Pump High Pressure Line Removal
Old Nov 14, 2016 | 02:03 AM
RamItDammit's Avatar
RamItDammit
Default Power Steering Pump High Pressure Line Removal
How do I remove this high pressure fitting from my power steering pump without messing it up?
Attached Thumbnails Power Steering Pump High Pressure Line Removal-20161113_224355.jpg
Old Nov 14, 2016 | 08:01 AM
You cant.
Old Nov 14, 2016 | 08:30 AM
You need to unscrew the fitting at the pump, that is a swaged union, and taking it apart will destroy it.
Old Nov 14, 2016 | 08:56 AM
RamItDammit
Thank you.
Old Nov 14, 2016 | 10:42 AM
AtomicDog's Avatar
AtomicDog
If you are concerned about that crimped fitting, its just cheaper to remove the entire hose and replace it. That fitting can be cut off with a wiz wheel (Dremel tool) and replacements can be obtained at hydraulic line and A/C line repair shops, but typically that's only practical for expensive hose assemblies.
