Having problems.
Old Nov 26, 2016 | 05:42 AM
TheMuffinMan's Avatar
TheMuffinMan
Default Having problems.
I have a 1997 Dodge ram 1500. After a while of driving with the high beams on my headlights try to shut off. I have no idea how to work on electrical so I was wondering before I tear it apart if someone knew what might be the reason it is messing up.
Old Nov 26, 2016 | 08:03 AM
Probably the switch is overheating. Need to pull the bezel around the cluster (carefully, they are easy to break), pull the switch, and have a look at the switch, and the connector. See what things look like.
Welcome to DF!
Old Nov 26, 2016 | 10:45 AM
Moparite's Avatar
Moparite
X2, You have 1500 this is what happens to the 2500 and 3500's.
