Exhaust Flange Bolts?
Old Dec 13, 2016 | 10:30 PM
racefan41's Avatar
racefan41
Default Exhaust Flange Bolts?
I discovered leaking at my on my exhaust flange so went to get this kit from HELP. I've never come across bolts that come with those clips. Any idea how/where they are used?
http://www.finddormanhelp.com/Produc...&cat=17&page=5
Old Dec 13, 2016 | 11:11 PM
racefan41's Avatar
racefan41
nevermind, it holds the head if the bolt in place and then has a tab that hooks over the flange so you don't have to have a wrench on both ends at the same time. helps to open it and play with it
Old Dec 14, 2016 | 07:17 PM
Moparite's Avatar
Moparite
If you haven't taken the old ones off yet you will discover that the bolt heads(and nuts) rust so bad neither a standard or metric wrench will fit it. I had to cut mine off with die grinder and cutting wheel. I replaced them with stainless steel, I also welded on a nut to the head of the bolt to keep it from turning.
Old Dec 14, 2016 | 07:30 PM
racefan41's Avatar
racefan41
cool, thanks for the heads up. I got to looking at those tabs and wondered how dependable they would be. I'm waiting for a "warm" day somewhere do get under there.
