Problem with ABS
Old Dec 18, 2016 | 05:18 PM
RamV10-'s Avatar
RamV10-
Default Problem with ABS
Good evening guys, I have a problem with the abs of my Dodge Ram 2500.
In practice, when I turn on the car (by pressing the brake pedal) the ABS and parking brake light are off but when I release the brake pedal the lights come on.
The ABS sensors (front L and R, rear differential) are ok.
The Brake light switch are ok.
can someone help me?
Thank you all
Old Dec 18, 2016 | 07:26 PM
What year is your truck? Does the speedometer work properly?
Old Dec 18, 2016 | 08:26 PM
dbbd1's Avatar
dbbd1
Way off topic here but how did that truck get to Italy?
Old Dec 19, 2016 | 06:57 AM
Moparite's Avatar
Moparite
In a shipping container! The same way the stolen(high end) vehicles from the us get over seas.
Old Dec 19, 2016 | 08:20 AM
RamV10-'s Avatar
RamV10-
hello guys, thanks for the answers. my truck was produced in 1999 and was imported in 2002 in Italy by a Dodge dealer. the speedometer is working properly, the problem occurs just release the brake pedal when stationary
Old Dec 19, 2016 | 08:44 AM
How's the brake fluid? Any of the line been changed lately? How is the pedal? Excessive travel? Spongy? Losing any fluid??
Old Dec 29, 2016 | 03:26 PM
RamV10-'s Avatar
RamV10-
hi to all guys today I changed the brake fluid but the abs light is always on just release the brake pedal when stationary.
i checked the brake light switch in the brake pedal:
when i press the brake pedal:
pins 1 and 2 continue
pins 3 and 4 does not continue
Pins 5 and 6 does not continue
Brake pedal released
pins 1 and 2 does not continue
pins 3 and 4 continue
Pins 5 and 6 continue
Pin 1 corresponds to the Brake Switch Sense
pin 2 corresponds to the ground
pin 3 corresponds to the speed control supply
pin 4 corresponds to the speed control brake output switches
pin 5 corresponds to the output brake lamp switch
pin 6 corresponds to the fused b (+)
-----making a bridge between the pins 5 and 6 the abs light comes on.
can someone help me? thank you so much
Old Dec 29, 2016 | 05:08 PM
You really need to have someone plug in with a scanner, and see what it is whining about.
Old Dec 29, 2016 | 05:25 PM
dbbd1's Avatar
dbbd1
In Italy, that might be a stretch...
There is something about the abs acting up if you drain too much fluid out. Doe thing about resetting it somehow. I'll look... (You can look too)
If I help, do I get to stay at your place for free?
Old Dec 29, 2016 | 05:30 PM
dbbd1's Avatar
dbbd1
While I'm looking, here is some info on the brake switch, but it does sound like it is working normally. Maybe the brake push/release thing is due to pressure in the master cylinder and the ABS actuator.
Attached Thumbnails Problem with ABS-brake-info001.jpg   Problem with ABS-brake-info002.jpg
