99 gear shifter stuck. Have 4 wheel posilock.
Old Dec 31, 2016 | 01:00 PM
shep28shep's Avatar
shep28shep
Default 99 gear shifter stuck. Have 4 wheel posilock.
My plow truck sits most of the year. Only used for plowing. Has 4 wheel posilock installed in place of factory vac. actuator. The floor trans gear shifter is stuck in place. Posilock works fine and engages 4 wheel drive. Ideas?
http://4x4posi-lok.com/app_dodge.html
Old Dec 31, 2016 | 01:14 PM
If it sits most of the time, is the linkage simply rusted up? Might try drowning it with some good penetrating oil... See if that doesn't help.
Welcome to DF!
Old Jan 3, 2017 | 12:09 AM
shep28shep's Avatar
shep28shep
I lubed the linkage from under the truck. It moves now, but still takes a lot of force to move the shifter. Fluid is full.
Old Jan 3, 2017 | 06:20 AM
97ramrod1500's Avatar
97ramrod1500
If spraying it down got it to move a little bit keep spraying it. And working it back and fourth. A good foaming penetrating oil will do wonders.
Old Jan 6, 2017 | 01:29 PM
marcar1993's Avatar
marcar1993
Yep, probably just frozen linkage. Just keep working it with lubricant.
