Ram Off Road 4 Wheel ABS?
Old Dec 31, 2016 | 02:51 PM
Skeptic68W's Avatar
Skeptic68W
Default Ram Off Road 4 Wheel ABS?
Hey guys,
I know the off road group on the 2nd gens made the truck rear wheel abs only (something about off road drivers not liking front wheel abs). I however, would very much like front wheel abs so I was thinking of changing it.
Does anyone know if this change was just done with the module? Can I swap in a standard abs module and get 4 wheel or are there more substantial changes that must be made?
Thanks and happy holidays.
Old Dec 31, 2016 | 03:39 PM
Need the module, and requisite brake lines, and I also think there needs to be programming for the PCM as well..... Not to mention front wheel speed sensors...
Old Dec 31, 2016 | 06:39 PM
adukart's Avatar
adukart
Best thing is to find a donor truck. There is a seperate abs module and pump for the 4whl abs. I doubt there is anything in the PCM since the speed signal routes first through the abs then to the PCM and cluster also the ABS is a stand alone module. If you ever went wheelin' you'd know why abs on the front sucks. Pretty much will let you free roll down steep slippery stuff.
