Headers
Old Jan 7, 2017 | 02:25 PM
Hemibuck's Avatar
Hemibuck
Originally Posted by AtomicDog
+1 on the JBA shorties. I have a set on my truck that I picked up here locally off craigslist. They fit great and perform well. Before that, I had a set of Pacesetter shorties and they didn't fit well into the stock exhaust pipes - I had to bolt one side on to the downpipe, then use a hydraulic spreader to position the other downpipe pipe into place properly.
My Pacesetters fit great. I don't remember having any problems with them. I'm just glad we have so much room to work on them. Not like on the Magnum. Those took forever!
Old Jan 7, 2017 | 02:36 PM
What? You didn't have your shoehorn, and hammer?
Old Jan 7, 2017 | 02:50 PM
Hemibuck's Avatar
Hemibuck
I think because the first set always needed re torqued I was just used to it.
Old Jan 7, 2017 | 03:06 PM
AtomicDog's Avatar
AtomicDog
My Pacesetter shorties bolted to the heads without any issue, but connecting them to the stock pipes on each side was a real challenge. No issue whatsoever with the JBA shorties.
Old Jan 7, 2017 | 03:13 PM
Hemibuck's Avatar
Hemibuck
Ahhh ok. I had all aftermarket no stock.
Old Jan 7, 2017 | 08:54 PM
2bit's Avatar
2bit
Originally Posted by 97ramrod1500
How long has your daughter had them on? I'm mostly concerned with the longevity of the headers
They've been on over a year. Brand name is Manzo IIRC. I'm really impressed with them. They are shorties not long tubes.
Old Jan 15, 2017 | 04:42 PM
97ramrod1500's Avatar
97ramrod1500
Alright so I got pretty lucky I guess. Bought a 97 ram sst for parts for $500. Guy found a set of Gibson shorty headers for it that have a small crack on 1 weld. Ill take these to work this week and tig the crack up and inspect the rest of the welds. Can't wait to get these installed!
Old Jan 16, 2017 | 12:25 PM
Hemibuck's Avatar
Hemibuck
You will like them. My first set but I didn't have access to have them fixed so I just replaced them with the Pacesetters. Funny is I found myself having to re-torque the other but the Pacesetters have not needed re-torqued for a long time! I gotta say if you get these on you should get a tune. I can't say enough about the tune and how it has woken up this truck it's crazy!
Old Jan 16, 2017 | 01:25 PM
97ramrod1500
I plan on getting a tuner eventually. First want to do the headers then step up to 35" tires and re gear to 4.56. Then after that ill tune it. Problem is I wish I could tune 2 vehicles off 1 tuner since I will need to tune my rat rod with the 97 5.9 also.
Old Jan 16, 2017 | 01:30 PM
Hemibuck's Avatar
Hemibuck
You may be able to tune more than one rig with the tuner. Send Shawn a message and ask.
