4Low Grinding Noise In Gear
Old Jan 8, 2017 | 08:36 AM
ballstimeballs's Avatar
ballstimeballs
Default 4Low Grinding Noise In Gear
Hello!
Looking for some help! Ive got a 99 ram 1500, 5.9 auto 4X4. My 4HI works flawlessly, 4LO is a different story. Went to engage it yesterday, and was surprised by a loud, constant grinding noise when trans is put in Reverse. Neutral and drive give me no noises, and it appears 4LO has engaged.
Am I looking at a new TCase in the near future? Wouldn't surprise me, its basically the only thing I havent replaced.
Thought I should mention, I have the cable actuated 4x4 Posi Lok system. No vacuum components So worth it BTW.
Old Jan 8, 2017 | 09:26 AM
ballstimeballs
So... Just went to go use 4HI when I got stuck, heard a loud CLUNK.. Thought something broke, but it appears 4HI still works in Drive. Reverse feels weird though, it looks like the front left wheel is binding.. Looked like I have 3 wheel drive. Any thoughts?
Old Jan 8, 2017 | 10:20 AM
You do have three while drive, but, only if you have a LSD in the rear. Front diff is open, so, power will be routed to the tire with the LEAST traction.
If you have a lotta miles on your truck, it's possible its just a stretched out chain in the t-case. Given your symptoms, wouldn't surprise me if that wasn't the case. Wouldn't hurt to have a close look at the shift linkage as well, and make sure there isn't excessive slop. Might not be completely engaged in 4 lo.
Old Jan 8, 2017 | 11:35 AM
dbbd1's Avatar
dbbd1
Have you looked at the snap ring in the tail housing of the trans? I'm thinking TC saver...
Old Jan 8, 2017 | 04:46 PM
ballstimeballs
Gotcha on the 4HI. Makes perfect sense, cause I rechecked 4HI again and it's working perfectly.. Did give me a bit of a scare though. I do have LSD, so it makes sense that I was drifting a bit to one side while in Reverse. I got 110k on the truck, but I know my current tcase was taken from a junker a couple years ago.
Are 4LO and 4HI driven by two seperate chains? Just thought it was weird only 4LO grinds in reverse.
Old Jan 8, 2017 | 05:02 PM
Nope, only one chain in the case. May want to try and localize the noise, and make sure it is indeed the t-case making the noise.
Old Jan 9, 2017 | 10:35 AM
ballstimeballs
I'll look into that.. I would think it has to be the case though..
