94 dodge ram 1500 5.9L wont start
Old Jan 9, 2017 | 06:36 PM
Hunter Fink's Avatar
Hunter Fink
Default 94 dodge ram 1500 5.9L wont start
Towed a trailer with a dirtbike once and after I shut off the truck it wouldnt turn back on. Replaced the crankshaft positioning sensor, ignition coil, cam sensor, and refurbished the PCM. Still no start. Cranks but wont start, no spark. No power to ignition coil. Has fuel pressure, even with fuel poured into the carborater it still wont turn over. Got laid off and moving to Sonora, Ca soon. Need my truck! Thanks.
Old Jan 10, 2017 | 09:45 AM
Do you get power to the fuel injectors while cranking?
Keep in mind, you will only see power at the coil, or injectors, for about 3 seconds, unless the PCM sees the engine turning.
Old Jan 10, 2017 | 11:20 AM
dbbd1's Avatar
dbbd1
Mopar CPM? What about time for a cam sensor?
Old Jan 10, 2017 | 05:15 PM
mda8569's Avatar
mda8569
How do you re-furbish the pcm? Also, kinda confused on what your issue is, will it turn over? You said you
" poured gas in the carb and still wont turn over"?
Old Jan 10, 2017 | 06:13 PM
Moparite's Avatar
Moparite
Cranks but wont start, Cranks= turns over.
You can check for power at the coil/injectors when cranking the motor. If nothing replace the ASD relay in the engine compartment box. If you have any codes post them.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
