really loud grinding noise when turning left
Old Feb 9, 2017 | 11:44 AM
Andrew Bryant's Avatar
Andrew Bryant
Default really loud grinding noise when turning left
i have a 1994 1500 4wd 5.2. it has a new track bar, tie rod ends, and bearing assembly but when i turn left from a stop it grinds really loud i just put 285-70-17 nittos on but its not a rubbing noise i dont know if that would casue it to grind
Old Feb 9, 2017 | 12:00 PM
U-joint going bad?
Welcome to DF!
Old Feb 11, 2017 | 10:40 AM
Andrew Bryant
U-joint going bad?
Welcome to DF!
i just replaced both less than a year ago. i did find out today i cant turn at all in 4wd
Old Feb 11, 2017 | 11:47 AM
Think I would be taking a close look at the joints anyway..... If it won't let you turn, I suspect one of the axles has shifted, and if you try and drive it like that, things are gonna break.
Old Feb 11, 2017 | 11:01 PM
2bit's Avatar
2bit
Check the wheel bearing.
Old Jan 23, 2019 | 10:02 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by Skreelink
Speaking of, bearings... bearings everywhere! Now there's a high pitch whine coming from the front of the engine between 900-1500RPM, around 2k it's gone. Seems to dissipate after the truck warms up enough to transfer heat into the pulleys. I'm hoping for idler pully or even tensioner pulley, as long as it isn't my alternator or water pump. I'll get a recording of this either tomorrow or this weekend, see what you guys think.
Take off the belt and spin everything by hand. I have a thread on how to regrease pulleys, if they aren't too far gone. https://dodgeforum.com/forum/2nd-gen...g-pulleys.html
You can check the water pump by simply grabbing the fan blades wide apart and rocking them. If there is even the slightest movement, change the water pump. Got mine done about 2 months ago. https://dodgeforum.com/forum/2nd-gen...t-removal.html
