Gear ratios on 4X4 from front axle to rear
Old Mar 11, 2017 | 04:19 PM
KDBone's Avatar
KDBone
Default Gear ratios on 4X4 from front axle to rear
The VIN decoder stated that there is a 3.55 minimum to 3.92 maximum on this truck. I need to replace the rear differential. Can I put either of these in the back or do I need to match the front? If I must match the front axle's ratio how do I definitively I.D. what is up there.
Old Mar 11, 2017 | 04:33 PM
Front and rear absolutely MUST be the same gear ratio. The stock ratio should be listed on a sticker, I think under the hood somewhere. Either that, or you can get a build sheet, and that will tell you what it came from the factory with. If you think someone has been in there before, then the only SURE way to know, is to pull the cover, and have a look. Gear ratio (or, tooth count) should be scribed on the ring gear somewhere.
Welcome to DF!
Old Mar 11, 2017 | 04:47 PM
KDBone's Avatar
KDBone
Thank you very much that really helps. It verifies information I had received concerning a sticker under the hood so I will look for it. Thanks again
Old Mar 11, 2017 | 08:48 PM
Ramman18's Avatar
Ramman18
You can put a different ratio in but then you have to remove the front driveshaft so no more 4wd. Works in a pinch. Or when regearing to save up.
Old Mar 12, 2017 | 02:30 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
If your front differential hasn't been messed with there should be a small silver tag under one or two of the cover bolts. You might have to scrape some grim off the tag before you can read it.
