46re torque converter clutch solenoid
Old Mar 14, 2017 | 02:35 PM
Jacob Peterson's Avatar
Jacob Peterson
Default 46re torque converter clutch solenoid
So I've been having some tranny issues lately and have been putting them off butt I decided to hook up the scan tool and came back with torque converter clutch solenoid I know how to replaced it but is there and other notes I should know before I do
Old Mar 14, 2017 | 04:03 PM
dbbd1's Avatar
dbbd1
If you are in there replacing that, you should also replace the governor pressure sensor and governor solenoid. Make sure to check your fluid level in neutral, false readings in park.
Old Mar 14, 2017 | 06:23 PM
Jacob Peterson
Anything else I should replace while there
Old Mar 14, 2017 | 07:07 PM
Over drive solenoid too. Plus fluid and filter. Adjust the bands. That's all you can do.
Old Dec 3, 2017 | 08:04 PM
KPU96's Avatar
KPU96
can you point me in the right direction on where I can learn how to replace this part ? Any information would be greatly aprechiated
Old Dec 4, 2017 | 07:34 AM
Factory Service Manual. Found here.
