Help a Ford guy out please!
Old Mar 31, 2017 | 11:57 AM
MasonArmstrong's Avatar
MasonArmstrong
Originally Posted by dbbd1
Nope. 19 or 90, we all have to start somewhere.
Although the Hughes is probably fine, there are other, maybe cheaper choices out there.
Can you recommend any other throttle bodies? So far I've only come across the hughes and the holley and the holley is way more expensive than hughes.
Old Mar 31, 2017 | 11:59 AM
dbbd1's Avatar
dbbd1
There's fastman and another, whose name eludes me right now.
There are some on fleabay even, but check out the seller ratings.
This is all off the cuff, I admit, I don't even know how much the Hughes runs...
Old Mar 31, 2017 | 12:40 PM
MasonArmstrong
Originally Posted by Moparite
Richmond has been around forever. Something else you should do if you don't already have is get a limited slip diff. You might want to upgrade the exhaust for better flow also with the other mods you plan on doing.
The truck has a dual straight pipe and im going to put headers on. Do you know where to find the axle code on a chrysler axle?
Old Mar 31, 2017 | 01:28 PM
dbbd1's Avatar
dbbd1
A bolt, holding on the diff cover, should have a metal tag on it stating the gear ratio that's in it.
Old Mar 31, 2017 | 07:39 PM
Moparite's Avatar
Moparite
If it's not on there look at the sticker under the hood. It will tell you if it has a limited slip and the ratio.
Old Mar 31, 2017 | 07:57 PM
Four hole injectors may flow better than the current, high-mileage stockers, but, they aren't a performance improvement. The stock injectors point the gas at the back of the nice, hot, intake valves, so, they not only cool the valves, but, the heat vaporizes the fuel.
Unshrouding them at the intake is an actual improvement.
Old Mar 31, 2017 | 08:04 PM
MasonArmstrong
So will the stock injectors be able to handle the added air intake of a bigger throttle body and intake?
Old Apr 1, 2017 | 09:17 AM
They should. There is some built-in 'overhead' on the flow rates.
Old Apr 1, 2017 | 10:09 AM
dbbd1's Avatar
dbbd1
What do you mean by this?
Old Apr 2, 2017 | 09:56 AM
Grinding out the inside of the injector hole in the manifold runner. I think there are pics around somewhere if what it looks like before and after.
