LED headlight problem
Old Apr 10, 2017 | 11:05 PM
MasonArmstrong's Avatar
MasonArmstrong
Default LED headlight problem
So i have a 98 ram 1500 with Spec-D dual halo LED projector headlights. I wanted a brighter bulb so I ordered V-plus 10K lumen LED headlights in a 9004/HB1 size, the factory bulb size. These bulbs are INSANELY bright but they wont fit in the new headlights, the hole for the bulb is way to small for the bulb to fit in, and the bulbs the headlights cane with are these tiny ones. Is there any way to retrofit the LED bulbs into my new headlights?
Old Apr 11, 2017 | 12:06 PM
You need to order the correct bulbs for the housings you have, not the factory housings. I guess if you are creative enough, you can figure out how to modify those to make the bulbs not designed for them fit.
