Rear window question
Old May 11, 2017 | 11:40 AM
RamDamn95's Avatar
RamDamn95
Default Rear window question
In my 95 regular cab I have a sliding rear window would a solid rear window fit no problem? Because I'm looking on eBay and the solid rear glass only says for 98-01? Would I just have to stick with buying another sliding one?
Old May 11, 2017 | 01:06 PM
Apparently, a lot depends on your cab configuration. It seems that the regular cabs use the same window from 94-01 for the 1500s, and up to 02 for the 3/4 and 1-tons. (they didn't change to the third gen body style until 03) Given yours is a standard cab, a window that would fit a 98, should also fit yours.
Old May 20, 2017 | 01:19 AM
Twmays's Avatar
Twmays
I broke the slider in my 01 quad cab a long time ago. Plexiglass I used to "fix" it finally broke too, so I had a glass shop replace it with a solid/single window. Fit just fine.
Old May 21, 2017 | 07:07 PM
'96 Power Wagon's Avatar
'96 Power Wagon
Here you go, brother:
