Transmission help please
Old May 12, 2017 | 11:00 PM
David thom's Avatar
David thom
Default Transmission help please
I just did a trans swap with a used trans out of a totaled truck. Dodge 46re. It goes into reverse fine but put it in drive and it won't hardly move.. if I rev the motor it will slowly start moving very slowly never picks up speed... but feels like it is not the drive train moving it.. did I do something wrong?? Any ideas would be helpful. Thanks
Old May 13, 2017 | 08:14 AM
Moparite's Avatar
Moparite
Do you know what condition the trans was in before you bought it since it was "used"? Might want to check the bands and pressures.
http://www.atraonline.com/manuals/se...0/2000_154.pdf
Old May 13, 2017 | 09:08 AM
What year is your truck, and what year was the truck the trans came out of?
Old May 13, 2017 | 04:59 PM
David thom's Avatar
David thom
I'm ignorant to transmissions.. my truck is a 98 the truck it came out of I have no idea.. was told it came out of a truck that got t-boned.. it goes into reverse fine. If I put in drive it just rolls forward slowly. It doesn't feel like it is pulling. But if I put it in park it grinds. It is 4x4. I've tried adjusting transfer case. That doesn't seem to help.would a bad t-case allow it to go into reverse and not forward?
Old May 14, 2017 | 10:16 AM
T-case has nothing to do with whether the trans works or not. If you can move it around in reverse, then the t-case is fine. (for purposes of moving the truck at least.....)
Try unplugging the 8 pin connector on the drivers side of the trans. Put it in first gear, and see if it wants to move better.
Old May 14, 2017 | 10:25 AM
David thom's Avatar
David thom
I'll try that after work thank you.
