Headlights
Old Jun 3, 2017 | 03:25 PM
5.9_MAGNUM_POWER's Avatar
5.9_MAGNUM_POWER
Default Headlights
I have a 99 sport ram. I am wanting to put aftermarket headlight assemblys on it. My problem is that my passenger side fender is ok, but my driver side fender is not a sport one. Will either assemblys work or will i have to buy each assembly seperate?
Old Jun 3, 2017 | 03:39 PM
What year was the donor truck for the drivers fender? I think the newer ones were all the same, sport or not.
A lot depends on what housings you want to go with. If you have sport housings (dual bulb) on both sides now, you can use whatever you want. Will have to do some creative wiring if you go with single bulb housings though.
Old Jun 3, 2017 | 07:44 PM
5.9_MAGNUM_POWER
pre 99. It has a single bulb housing in it now
Old Jun 4, 2017 | 09:19 AM
Ah, if you want to put a sport housing in that one, probably going to have to do a bit of body work. If you put stock housings in, they will just bolt right on. (both sides) Just have to modify the wiring for the single bulb system.
Old Jun 4, 2017 | 11:08 AM
5.9_MAGNUM_POWER
What kind of body work
Old Jun 4, 2017 | 12:18 PM
Clearancing out the fender where the sport housing would want to fit. If you pull both housings, you will be able to see exactly what needs to happen.
Old Jun 4, 2017 | 12:52 PM
5.9_MAGNUM_POWER
Sweet thanks
