360 knock
Old Jun 14, 2017 | 01:50 AM
Rww2's Avatar
Rww2
Default 360 knock
What should oil pressure be? Mine below 40. Knocks on a pull, when pressure above 40 no knock. Sounds like a rod bearing? 123 oo mileage.
Old Jun 14, 2017 | 08:37 AM
Typically, most manufacturers want to see a minimum 10 PSI at idle, on a fully warmed up motor, and then 10 PSI more / 1000 RPM.
My take on it is: If your pressure is that low at idle, then you need to rebuild the motor. If you are getting rod knock at low RPM, that also means its time for a rebuild.
Welcome to DF!
