HEADLIGHT CONVERSION
Old Nov 21, 2005 | 04:35 PM
ACB97SLT's Avatar
ACB97SLT
Default HEADLIGHT CONVERSION
IS THERE A STRIGHT FORWARD WAY TO MODIFY MY 97 RAM HEADLIGHTS SO THAT WHEN THE SWITCH IS IN THE HI-BEAM POSITION, MY HIGHS AND LOWS COME ON, AND IN THE LOW BEAM POSITION, ONLY THE LOW BEAMS?
Old Nov 21, 2005 | 04:57 PM
01ramclassic's Avatar
01ramclassic
Default RE: HEADLIGHT CONVERSION
I don't know of a way to wire it that way, but that doesn't mean there isn't a way to though. One way to have both High and Low beams on at once is to pull back on the light switch and hold. As long as you hold the switch back both beams are on. This is bright but I just intalled some factory foglights on my truck and the visibility while driving is really great. I'd say it's alot better than both high and low beams, come to think of it...I don't even use my high beams anymore since I got foglights. -Tyler
Old Nov 21, 2005 | 06:00 PM
The Burning Rom's Avatar
The Burning Rom
Doing a search would yield you some results
Or you can check out this thread: http://www.dieseltruckresource.com/d...ght=headlights
You'll have to register to view it though.
Old Nov 21, 2005 | 06:54 PM
Tani1500's Avatar
Tani1500
oh be nice to the new guy. he doesnt have to search if he doesnt want to oh and welcome to DF man!
Old Nov 22, 2005 | 03:23 AM
hometheaterman's Avatar
hometheaterman
Yeah my low beams with factory fogs is a good setup I wish the fogs didn't run off when I switched my high beams on and I don't want to rewire it. It would be an awesome setup if they stayed on.
Old Nov 23, 2005 | 01:10 PM
ACB97SLT's Avatar
ACB97SLT
JUST WHAT I WAS LOOKING FOR. THANKS FOR THE HELP FOR THE NEWBIE!
Old Nov 24, 2005 | 05:07 AM
arkansasmp's Avatar
arkansasmp
home theaterman-- if you look at the relay o the foglights there is a wire that is crimped to the low beam wire if you disconnect that wire then you fogs stay on all the time i did it for offroading
Old Nov 26, 2005 | 02:57 AM
shott8283's Avatar
shott8283
yea if you pull back on the light turn signal stalk on the colum and hold it both LB and HB come on..so that tells me that the switch is just a plain old double throw sing pull with a hold..or maybe a double throw and and double pull...and a hold.. and could be easily rewired to what you want.. nice thinking... thanks for the idea!!!
