my mexican 96 ram... help
Old Jun 17, 2017 | 01:24 PM
rogelioifmradio's Avatar
rogelioifmradio
Default my mexican 96 ram... help
Hi guys, i recently acquired a 1996 ram 2500, i live in mexico so my ram is mexican model as well, here are some things about my ram you should know before i get to the point on this thread
it is a 5.9 gas Ram but...although is a 1996, my truck came out factory with the old tbi system, so it is not a mpfi
it has a 3 speed automatic tranny
no one has been able to figure out the vin, no even at the mexican dealership. they don't have records of that model on the computer and i am having trouble getting the parts because in the parts store their catalog shows a modern configuration instead of the old one.
this is my vin 3B7HC2672TM111967
NOW TO THE POINT.-
i found out the factory alarm module ( under the center seat ) still works, it has only one connector and when connected the horn sounds and the lights start flashing. so i went to eBay and got a factory key fob ( because i didn't have one ) but i am having problem getting it programmed. is there anybody here who could help me with this issue ?
went to 3 locksmiths and say its too old for their equipment, and the dealership has no idea about the truck. here are some pics of the module
Attached Thumbnails my mexican 96 ram... help-img_4837.jpg   my mexican 96 ram... help-img_3648.jpg   my mexican 96 ram... help-img_4843.jpg
Old Jun 17, 2017 | 01:40 PM
No clue if this will work or not.... But, give this procedure a shot. Let us know if it works.
Old Jun 17, 2017 | 02:32 PM
rogelioifmradio
can't find that green wire, theres no wire that fits the description in there
Old Jun 17, 2017 | 02:42 PM
I can't find anything on it in the service manual.......
How about either of these methods?
Old Jun 17, 2017 | 03:10 PM
rogelioifmradio
thanks, i am gonna try procedure 1, let me see if i can find that override button.
already tried procedure 2 but the data link conector doesn't have a wire on slot 1, its not broken, its just that there no wire at all from factory
Old Jun 17, 2017 | 03:45 PM
Wonder if it got pulled out somewhere??? Not hanging around loose by any chance?
Old Jun 17, 2017 | 03:48 PM
rogelioifmradio
no wire at all, harness is clean.
i just tried procedure one and guess what? no override button at all...
Old Jun 17, 2017 | 03:51 PM
Not surprising......
Seems everyone and their cousin has a different procedure though. I googled "96 dodge ram key fob programming", and came up with a long list of possibilities...... Give it a shot, you may get lucky.
Does the local dealer still have manuals for your truck? There may have been some supplement or other dealing with keyless entry/alarm systems.
Old Jun 18, 2017 | 08:29 AM
Moparite's Avatar
Moparite
See if you can look up the part # on the module. You may be able to get some info that way. I wonder if the module is used in the same gen rams as in the states or it is old equipment such as the tbi that came from the 80's/90's?
Old Jun 19, 2017 | 12:54 AM
rogelioifmradio
Thanks, i also believe the module is from an older model from the late 80s or early 90s. part number is 4790682, i tried to find it on eBay but nothing came out
