bad miss on 2001 ram magnum
Old Jul 7, 2017 | 04:57 PM
Torxhead's Avatar
Torxhead
Thanks for the response, determining if your issue is electrical or fuel can be a tough one. Did you get any new codes sent?
Old Jul 7, 2017 | 07:14 PM
trevorhull1911's Avatar
trevorhull1911
Default No new codes
As of yet no new codes have popped up
Old Jul 7, 2017 | 09:03 PM
97ramrod1500's Avatar
97ramrod1500
Have you checked fuel pressure? Check that and compression to verify then look into the electronics.
Old Jul 8, 2017 | 01:06 PM
trevorhull1911
Default Found it.
I wish I had checked compression first. It would have saved a lot of money. Compression on every cylinder is hitting at 80 lbs. I am guessing verified by a mechanic friend that it has jumped time by a notch or 2. That would cause the valves to open as the compression is building meaning loss of pressure not firing properly and so forth. Next weekend I am changing the timing chain and gears and hopefully that will fix it. Give me your feedback and let me know what you think.
Old Jul 8, 2017 | 04:07 PM
Certainly cant hurt.
Did you try a wet test as well? Did it change anything?
Old Jul 14, 2017 | 01:02 PM
trevorhull1911
Default Timing
Just checked the timing chain and gears. It's in time so what is left to cause compression of80 to 85 lbs? Rings?
Old Jul 14, 2017 | 01:40 PM
Rings or valves... Maybe both. Leakdown test would give you a better idea.
Old Jul 14, 2017 | 02:59 PM
trevorhull1911
Default Back to the original problem
Ok. My original problem was a bad miss. Would bad rings cause a miss or just loss of power? I don't want to get sidetracked by other issues until I fins the miss. I followed the loss of compression thinking it might be out of time but since it's in time thats nor it. Any other ideas?
Old Jul 14, 2017 | 05:53 PM
Low compression will give you a miss. Could try doing the compression test again, dry first, then wet, see what the numbers do.
