Rattle sound on motor
Old Jul 2, 2017 | 09:17 PM
Lof's Avatar
Lof
New Member
Default Rattle sound on motor
Hi Everyone !
I have a little concern with my Dodge
There is a kind of rattle sound coming from a hose.
It's the hose starting from the oil compartment
If any one have an idea of what that can be !
It's inside the hose, it's not something moving. Like there is air and liquid together passing through the hose.
Thank you so much
That little guy here
Old Jul 2, 2017 | 10:08 PM
PCV valve. That's normal.
Welcome to DF!
Old Jul 10, 2017 | 02:40 PM
jlake4130's Avatar
jlake4130
Just replace the PVC valve. Toughest part is if it is the original the rubber grommet in the valve cover will be rock hard and most likely break during removal (careful not to let broken pieces drop in the valve cover). Finding the correct size grommet at a local autozone, etc is unlikely. Order a new one online and replace the PVC and grommet when it arrives.
