Smoke and oil
Any ideas are helpfull, was driving my 95 dodge ram and it began smoking behind me, went about a mile n turned around n came home, after getting out there was oil All over the ground under it, what looks like the back of the motor, thing main rear seal.. truck still runs good tho, and there is still oil on the stick, way more than i figured would be on it, so is it the seal possibly? And if so is that hard to replace? Thanks for any suggestions
Need to figure out if it is oil, or trans fluid, or something else entirely. Hows the fluid in the trans look? (need to check fluid in neutral. Checking in park will give you an artificially high reading.)
Welcome to DF! Moving this to second gen ram section for ya.
Tyvm wasnt sure where to ask, yes it is motor oil, the tranny fluid is good and it looked like about a quart, maybe 3/4 of a quart was on ground... looking around once it dried a lil n cooled, dont really look like oil leaking anywhere but the rear seal, could it have maybe had a hose clogged and blew out of the rear seal? Just trbl shooting possibilities ty for ur time
No hoses that carry oil, and oil shouldn't be pressurized by the rear main.
Try running the engine a bit, and see if anything obvious presents itself. Also, open the hood, take off the oil fill cap, with the engine running, and put your hand over it, you should feel just a bit of suction.
Reasoning here is: Oil filter is right in that neck of the woods as well.... but, I wonder if the pcv system isn't working, and the crankcase is getting pressurized, and that would certainly blow out the seal.
