harmonic balancer?
Old Jul 28, 2017 | 02:21 PM
  #21
acain's Avatar
acain
Thanks heyyou.. I just called the parts store and the guy says they put two different sizes on that year. ones 24 bucks the other ones 75 bucks. Why would they put different sizes on the same year same model. doesnt make sense to me. he couldnt tell me what the difference was.
Old Jul 28, 2017 | 05:33 PM
  #22
Wonder if it is due to different bed lengths, or something equally as esoteric. Grab the parts manual for your truck from the FAQ section, and see if you can look up a number, parts store should be able to cross-reference that.
Old Jul 31, 2017 | 10:08 AM
  #23
acain's Avatar
acain
well, I swapped out the center bearing over the weekend. no change. I wont go into all the details but eventually I found somebody with a scanner even though I was thoroghly convinced the problem was under the truck. The guy says its showing cylinder 2 3 4 7 and 8 mis-fireing. also an issue with an o2 sensor left , down stream. what ever that means. I believe the o2 sensor has been throwing a code since the engine was replaced eons ago. wouldnt swear to it. The shaking and vibrating happens right around 1200 rpms ands stops almost instantly once its past that. I can make the vibration happen at the right speed (around 45-50) by depressing the gas pedal in, out.. in, out... in, out.. (rattle, stop.. rattle, stop.. rattle, stop). the guy with the scanner said to check the distributor, rotor and cap. Im just frustrated at this point, and the distributor by the way, is back behind the engine and next to impossible to get too. Soooo... now what.
Old Jul 31, 2017 | 10:59 AM
  #24
Rear O2 (downstream) only monitors cat efficiency.
Try unplugging the FRONT O2 sensor, and see if the truck runs any better.
Old Aug 1, 2017 | 01:09 AM
  #25
AtomicDog's Avatar
AtomicDog
Curious - how old is your distributor? Is it the same one that was off the original motor #1?
Old Aug 1, 2017 | 01:45 PM
  #26
acain's Avatar
acain
A D, I believe the distributor was on this motor when I bought it.
Old Aug 1, 2017 | 08:06 PM
  #27
AtomicDog's Avatar
AtomicDog
It would be good to pull the cap off of it to determine if you have any side to side play in the mainshaft of the distributor that the rotor sits on.
Old Aug 2, 2017 | 08:37 AM
  #28
acain's Avatar
acain
Ill try taking a look at lunch today as well *** unplugging the front o2 sensor as was suggested.. if I can. gotta be a cross between a spider and a slinky to get to the darn distributor cap... why the heck.. now my right rear brake is locking up . Mabey its time to think about a new ride.
Old Aug 2, 2017 | 08:39 AM
  #29
How old are your rear brake shoes?
Old Aug 3, 2017 | 08:09 AM
  #30
acain's Avatar
acain
oh, probably ten or eleven years old? I pulled the drum, and suprisingly, the shoes dont look bad at all, but all the components and mechanisms have just kind of fallen appart in there. The poor old guy just needs a major work over top to bottom Im affraid. I work pretty much seven days a week and usually twelve and thirteen hour days. Have been for years. Its a tough old truck but I guess it needs some attention. just never time.
