new PMC no security
Old Jul 28, 2017 | 01:12 PM
Pipper444's Avatar
Pipper444
Default new PMC no security
New programed ECM now I don’t have security do I need to get it EMC programmed again I don’t have a fob it was fine before replacing the PMC any ideals
1998 Ram 1500 4dr Quad cab WB 5.2, Central Timer Module: controls RKE, chime, courtesy lamps, Speed sensitive Intermittent wipers, enhanced accident response, VTSS.
Got the ECM reprogrammed to vin# now I can't get the security to work The BRD scan tool must be used wright? I'm reading the manual wright it looks like if it's started twelve times the VTSS the no-run feature enable logic will apply any time the PCM is Replaced with a new one. So will it start working after twelve starts or do I need to take to enable it with the BRD scan tool?
Old Jul 28, 2017 | 01:27 PM
Thought that was a product of the CTM?
Old Jul 28, 2017 | 02:34 PM
Pipper444's Avatar
Pipper444
Default no secuerity, reprogrammed ECM
Got the ECM reprogrammed to vin# now I can't get the secuerity to work The BRD scan tool must be used wright? I'm reading the manual wright it looks like if it's started twelve times the VTSS the no-run feature enable logic will apply any time the PCM is Replaced with a new one. So will it start working after twelve starts or do I need to take to enable it with the BRD scan tool?
Old Jul 28, 2017 | 02:40 PM
Pipper444's Avatar
Pipper444
