External Voltage Regulator + Tranny LIMP mode
Old Aug 9, 2017 | 12:52 PM
Fullthrottle1987's Avatar
Fullthrottle1987
Exclamation External Voltage Regulator + Tranny LIMP mode
My PCM is dead ( burned diode )
I will install a external voltage regulator for my alternator Field.
but, since my PCM is dead, my tranny won't shift into o/d.
Do you think the voltage regulator will solve my transmission problem ?
What is the voltage of the blue wire ? ( GEN SOURCE ) Is it 12V ?
thank you
Old Aug 9, 2017 | 12:58 PM
What year is your truck?
Old Aug 9, 2017 | 01:29 PM
Fullthrottle1987
Ram 3500 2001 , cummins engine, 4x4 . aut. tranny.
Old Aug 9, 2017 | 01:51 PM
Dark blue wire from alt should be whatever voltage it is putting out. If it is working properly, should be 14-15 volts, if the engine isn't running, should be battery voltage.
