Seatbelts won't lock when I pull them.
Old Aug 21, 2017 | 11:37 AM
RAS_Krav's Avatar
RAS_Krav
Originally Posted by ramsportrocks
im sorry I misunderstood, I thought you meant they wouldn't stay locked in the receiver.. you mean the inertia device isn't stopping the belts on hard braking....
FYI just a quick pull isn't enough to see if they are locking, you have to be moving .. get the truck up to about 30mph ( 48 KPH )
and hit the brakes hard and they should lock up
That's also a trick to test, thanks!
Today I got some more information from my "Dodge dealer" about the system. It works when you have impact. A switch (two metal blocks) will be activated and tighten the seatbelt.
Each seatbelt (sides) have this system. So you can't force it. But indeed what you say, it's worth to try when I got some speed!
Excuses for my English ;-)
Can anyone confirm this?
Old Aug 21, 2017 | 11:40 AM
RAS_Krav's Avatar
RAS_Krav
Mine will lock just sitting in my driveway, when I step on the brake......
Maybe there are different systems? Mine won't, only the ones build in the chairs. They have the same system as the most European cars.
Old Aug 21, 2017 | 03:21 PM
ramsportrocks's Avatar
ramsportrocks
possibly they changed it for 98 model year my SS/T is 97 and so was my ramsport and neither one would lock when brakes were hit parked.. had to be at speed..
Old Aug 21, 2017 | 03:30 PM
RAS_Krav's Avatar
RAS_Krav
I'll test it when possible and will give result here.
Very curious right now
Old Aug 22, 2017 | 09:13 AM
RAS_Krav's Avatar
RAS_Krav
I can confirm it now, my '97 need speed to lock the seatbelts. I need a speed about 18 or 20 mph...hit the brakes hard and the seatbelt press me back in the chair. Mysterie solved. Thanks for all advice!!
Old Aug 23, 2017 | 07:48 AM
ramsportrocks
youre welcome.. between the lot of us you should get a correct answer
Old Aug 23, 2017 | 12:30 PM
RAS_Krav's Avatar
RAS_Krav
...and we all together are the best specialist
