00 1500 fuel pump now leaking can be fixed?
Old Aug 27, 2017 | 07:56 PM
comet424's Avatar
comet424
Default 00 1500 fuel pump now leaking can be fixed?
hi
I just finished getting tranny and the fluid into this truck been over a month since I was working on it... so finally got it ready to start and when it was running seen gas leaking figured maybe a line as the gas tank did drop due to straps broke in the mean time and fell... well I pulled it down and I couldn't see broken line but I put a thumb over the output and had someone turn key on and she started leaking at the top where the pipe comes out but then I figured maybe thumb over the hole too much pressure and causes it to leak.. so I tried a hose and kinked it a little but leaks a bit its it because too much pressure and could be the line or is it the pump... and can I have this welded here is a video
Old Aug 27, 2017 | 08:37 PM
pershingd's Avatar
pershingd
Unless someone has a better answer, I think it make more sense to just replace the fuel pump module and be done with it.
Old Aug 28, 2017 | 11:10 AM
comet424's Avatar
comet424
ah ok
ya I having issues there is 3 pumps for this tank I have
26/34gal tank
26 gal tank
36 gal tank
you need to know size of tank and if your tank has 0 1 or 2 ports.. well my tank has 3 but 2 on the pump do they count that... 1 on top 1 overflow 1 filler and 2 on pump so 5
Old Aug 28, 2017 | 07:26 PM
pershingd's Avatar
pershingd
Run your VIN on the VIN decoder and see if that gives you some info on the tank. It's in the tools menu at the top of the page.
