Transmission linkage loose
My 1997 Ram 2500 4x4 shift linkage is loose and very sloppy. I have replace the bushing and everything else seems fine except where the linkage attaches to the transmission. I cant see very well but there appears to be a plate that attaches to a pin or a rod that goes into the top of the transmission that is very loose. this causes a problem with starting it in Park and I have to shift into Neutral to hit the starter safety switch. Also it prevents the truck from going all of the way into park and it tends to roll away as I get out. Can I fix this or does it need to go to a shop? I am not a tranny person
Is the slop on the outside? Or inside the trans? If you can actually see what the problem parts are, you likely could just order them, and replace them yourself. Really only need basic hand tools.
Welcome to DF!
Welcome to DF!
