battery drains overnight
Old Sep 1, 2017 | 09:02 PM
ricathebic's Avatar
ricathebic
Default battery drains overnight
how to test what it is
Old Sep 2, 2017 | 08:49 AM
Moparite's Avatar
Moparite
Need more info, Was the battery load tested? How old is it? May be the battery itself if not you can use an amp probe and pull fuses to determine what is draining it.
Old Sep 2, 2017 | 02:54 PM
brian102's Avatar
brian102
stereo / amp install recently?
Old Sep 5, 2017 | 11:08 AM
5.9_MAGNUM_POWER's Avatar
5.9_MAGNUM_POWER
Check the wiring close to the starter. Mine have grounded themselves out and drained the battery
Old Sep 7, 2017 | 11:14 AM
99sportram's Avatar
99sportram
https://dodgeforum.com/forum/3rd-gen...ery-drain.html
This post should help you, you need to troubleshoot the same way he did.
