driving vibration
Old Apr 11, 2018 | 12:01 PM
  #71
2bit's Avatar
2bit
If your drums were warped, turning them makes the hole round again, but not the drum. Because they were warped out of round, you now have thick spots and thin spots in the drum from making the hole round again. The heat from braking will make the thin spots hotter and the drum will warp again. Warped drums and rotors need to be replaced.
Old Apr 11, 2018 | 03:11 PM
  #72
chromed95's Avatar
chromed95
Hmmm that makes sense. I didn't think of that. I did know that they were prone to warp again, but figured this was a cheap option for diagnosing purposes vs buying new drums to diagnose with.
Road force balance sounds like a good idea. New drums sound like a good idea. Probably have to wait until i get my red head core refund back to get new drums.
Had my wife run it up to 60 on the stands while I watched the trans and driveline, all looked solid, no movement.
Getting closer indeed.
Old Apr 11, 2018 | 07:47 PM
  #73
2bit's Avatar
2bit
You said it was smooth until you put the wheels on. Maybe swap the front wheels onto the back. Or borrow a set from a friend with a Dodge? You may be right about a bent rim.
Old Apr 11, 2018 | 10:59 PM
  #74
chromed95's Avatar
chromed95
Yes it was, and I will swap front to rear. After that I plan to get it road force balanced, maybe they can spot a bent wheel. If nothing changes, then I'll try new drums.
Old Apr 11, 2018 | 11:36 PM
  #75
Ramman18's Avatar
Ramman18
Drums are cheap option. I always just replace rotors/drums as they're only about 40 bucks. If you do all new rear brakes at least you can eliminate them.
Old Apr 19, 2018 | 11:24 AM
  #76
chromed95's Avatar
chromed95
Well, I've got new drums, new shoes and hardware and new wheel cylinders. The shake is much better, but still there. Ran it up to 60 without the wheels on, just the new drums etc and it was smooth, hardly any shaking or vibration. Put the wheels on and the shake came back but not to the degree it was with the old drums on it.
I think I've got a bent wheel or hub in the rear. When on jack stands watching it turn in drive, the tire has noticeable side to side movement. I was going to take a front tire off and put it on that rear one, but I had no time. I think my next step is to take it to somebody who can properly diagnose if I have a bent hub or wheel. Not sure how the hub could of been bent, I would think the wheel would of bent first anyways. Haven't hit any huge teeth cringing potholes in this truck.
Old Apr 20, 2018 | 01:26 AM
  #77
Ramman18's Avatar
Ramman18
How's the rear end? Pinion bearing okay? If issues at the hubs, there maybe issues in the pumpkin.
